[GRASS-dev] [GRASS GIS] #2309: Add a select all flag to v.edit
trac at osgeo.org
Tue Jun 16 08:37:26 PDT 2015
Reporter: wenzeslaus | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: trivial | Milestone: 7.1.0
Component: Vector | Version: svn-trunk
Resolution: | Keywords: v.edit, feature selection
CPU: Unspecified | Platform: All
Comment (by wenzeslaus):
Replying to [comment:1 mlennert]:
> I've attached a patch that provides a very simplistic approach to a
"select all" flag.
Thanks.
> However, reflection is needed on the following questions:
> * Should the flag select all features, regardless of whether they have a
category number of not ?
> * If not should the flag select only features that have category numbers
in a given layer ?
In the example in the original report, the `layer` option is used to
specify the layer to write the categories to, so it cannot be used for
selection, so there is no "given layer". And since there is no given
layer, there is no way to determine if the features have category or not.
So for me the answer for both questions is select regardless of existing
category. This will do well for simple cases, I'm not sure if there are
any complicated cases when a more sophisticated approach would be
appropriate.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2309#comment:3>
