[GRASS-dev] Debugging QGIS with GRASS provider on Windows
Radim Blazek radim.blazek at gmail.com
Tue Jun 16 11:01:31 PDT 2015
I need to debug QGIS GRASS provider on Windows. I have successfully
compiled GRASS 7 using MinGW [1] and QGIS using MSVC [2]. The problem
is that MSVC does not support GCC debugging symbols and vice versa. Do
you have any idea how to debug both QGIS and GRASS code at the same
time, preferably in MSVC or Qt Creator?
Is there any recent effort to compile GRASS with MSVC? I have only
found quite an old mail about MSVC port [3].
Radim
[1] https://trac.osgeo.org/grass/wiki/CompileOnWindows
[2] https://htmlpreview.github.io/?https://github.com/qgis/QGIS/blob/master/doc/INSTALL.html#toc12
[3] http://lists.osgeo.org/pipermail/grass-dev/2007-November/034108.html
