[GRASS-dev] [GRASS GIS] #2648: v.concave.hull fails with small number of points
trac at osgeo.org
Wed Jun 17 08:29:52 PDT 2015
Reporter: annakrat | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.1
Component: Addons | Version: unspecified
Resolution: | Keywords: concave hull
CPU: Unspecified | Platform: All
Comment (by annakrat):
Replying to [comment:5 mlennert]:
> Replying to [comment:3 mlennert]:
> > Replying to [ticket:2648 annakrat]:
> > > Tested with 3, 4, 5 points, v.concave.hull fails. Depends on
threshold and point configuration, too.
> > > ERROR: Input vector map contains no boundaries.
> > > ['v.centroids', '--q',
'input=concave_hull_tmp_31390_delaunay_borders_select',
'output=concave_hull_tmp_31390_delaunay_areas_select'] ended with error
> > AFAICT, the algorithm cannot calculate the hull because the threshold
is too high. For now I've added a fatal error in the script with a hint
about the threshold (r65495).
> I've changed it again in r65496: the algorithm now automatically reduces
the threshold if it is too high and only fatals out if even a threshold of
0 wouldn't work.
Thanks, this works for the case. But for some point configurations, the
algorithm still doesn't produce what I would expect, for example these
points where the concave and convex hull should be the same I think, but
are not:
echo "638597|220531
638838|220526
638757|220237
638606|220331
638651|220576.08
638735|220601.28
638798|220578.18
638856.8|220456.38
638886.2|220292.58
638644.7|220256.88
638579.6|220437.48" | v.in.ascii in=- out=points --o
v.concave.hull input=points out=hull --o
I don't know what could be done about it. Maybe we could consider this
ticket as solved. Thank you
Ticket URL: <https://trac.osgeo.org/grass/ticket/2648#comment:6>
