[GRASS-dev] [GRASS GIS] #2648: v.concave.hull fails with small number of points
trac at osgeo.org
Thu Jun 18 01:36:54 PDT 2015
Reporter: annakrat | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.0.1
Component: Addons | Version: unspecified
Resolution: fixed | Keywords: concave hull
CPU: Unspecified | Platform: All
Changes (by mlennert):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:6 annakrat]:
> Replying to [comment:5 mlennert]:
> > Replying to [comment:3 mlennert]:
> > > Replying to [ticket:2648 annakrat]:
> > > > Tested with 3, 4, 5 points, v.concave.hull fails. Depends on
threshold and point configuration, too.
> > > > ERROR: Input vector map contains no boundaries.
> > > > ['v.centroids', '--q',
'input=concave_hull_tmp_31390_delaunay_borders_select',
'output=concave_hull_tmp_31390_delaunay_areas_select'] ended with error
> > > AFAICT, the algorithm cannot calculate the hull because the
threshold is too high. For now I've added a fatal error in the script with
a hint about the threshold (r65495).
> > I've changed it again in r65496: the algorithm now automatically
reduces the threshold if it is too high and only fatals out if even a
threshold of 0 wouldn't work.
> Thanks, this works for the case. But for some point configurations, the
algorithm still doesn't produce what I would expect, for example these
points where the concave and convex hull should be the same I think, but
are not:
> echo "638597|220531
> 638838|220526
> 638757|220237
> 638606|220331
> 638651|220576.08
> 638735|220601.28
> 638798|220578.18
> 638856.8|220456.38
> 638886.2|220292.58
> 638644.7|220256.88
> 638579.6|220437.48" | v.in.ascii in=- out=points --o
> v.concave.hull input=points out=hull --o
The PostGIS ST_ConcaveHull fonction authors agree with you as whatever the
precentage I set, I always get the convex hull as a result.
> I don't know what could be done about it.
I don't either. I don't even know if there is one "correct" definition of
a concave hull.
> Maybe we could consider this ticket as solved. Thank you
Yes, I'm closing it. If you want to discuss the general results of
v.concave.hull, thus probably warrants another ticket.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2648#comment:7>
