[GRASS-dev] Debugging QGIS with GRASS provider on Windows
Maris Nartiss maris.gis at gmail.com
Fri Jun 19 00:44:21 PDT 2015
2015-06-19 10:35 GMT+03:00 Radim Blazek <radim.blazek at gmail.com>:
> I have somehow managed to compile limited GRASS core libs with MSVC
> and GRASS Makefiles replacing gcc by cl.exe. The build system does not
> seem to be the biggest problem, there are still pieces of code not
> compiling under MSVC however.
If you are ready to test changes, could you report issues with code in
trac? Then it would be possible to check if existing code can be
accommodated to compile with both GCC and MSVC.
Maris.
