[GRASS-dev] Debugging QGIS with GRASS provider on Windows
Radim Blazek radim.blazek at gmail.com
Fri Jun 19 01:19:03 PDT 2015
On Fri, Jun 19, 2015 at 9:44 AM, Maris Nartiss <maris.gis at gmail.com> wrote:
> 2015-06-19 10:35 GMT+03:00 Radim Blazek <radim.blazek at gmail.com>:
>> I have somehow managed to compile limited GRASS core libs with MSVC
>> and GRASS Makefiles replacing gcc by cl.exe. The build system does not
>> seem to be the biggest problem, there are still pieces of code not
>> compiling under MSVC however.
> If you are ready to test changes, could you report issues with code in
> trac? Then it would be possible to check if existing code can be
> accommodated to compile with both GCC and MSVC.
I would like to, it was originally my aim to also submit patches, but
being stressed by time (QGIS release July 26), I am just putting hack
over hack to get it running and debuggable to be able to fix bugs for
the release.
Radim
