[GRASS-dev] Planning GRASS GIS 6.4.5 release
Moritz Lennert
mlennert at club.worldonline.be
Mon Jun 22 07:05:52 PDT 2015
On 22/06/15 14:50, Vincent Bain wrote:
> Hi,
> sorry for the following confused remark : using 6.4.5 (right now rev.
> 65516) on a daily basis I sometimes (rarely) have an issue with wxGUI,
> but can't foresee when it happens :
> consider a workspace composed of several quite big vector maps. Select
> "Digitize" from the pull-down menu in the map display window. Then
> select the name of the vector map to edit : sometimes the current edited
> map will not be the one I choosed but another one in the layer tree, and
> this particular map is impossible to select from the list... Digitizing
> the map can always be performed the right way by selecting "Start
> editing" from the right-click menu in the layer tree.
> I did not find a particular situation when it occurs, except that :
> -it's always concerning big vector files (i.e. contour maps),
> -it does not happen if the layer tree contains only one vector map (the
> one I want to edit).
> Sorry again for the lack of formal clues but perhaps this point should
> be considered blocking for a stable release. Hope some of you can
> reproduce this bug or have some idea about what can be wrong there.
Can you give us data and a procedure to make this reproducible ?
Moritz
