[GRASS-dev] temporal modules cannot open database
Sören Gebbert
soerengebbert at googlemail.com
Thu Jun 25 02:53:32 PDT 2015
Hi Luca,
i just committed a patch in SVN that can handle modified location path's.
Please make an update of grass7.1 and then call t.connect -d in the
specific location/mapset to reset the default connection, which is
mapset specific.
I hope the temporal framework will find the correct database again.
Best regards
Soeren
2015-06-25 11:30 GMT+02:00 Luca Delucchi <lucadeluge at gmail.com>:
> On 25 June 2015 at 00:05, Sören Gebbert <soerengebbert at googlemail.com> wrote:
>> Hi Luca,
> Hio Soeren
>> is it possible that the path to the location has changed or that the
>> location was renamed?
> mmm I don't think so, but I'm not sure.
> The path to db it seems correct using t.connect -l, do you have any
> trick to solve this problem?
>> Best regards
>> Soeren
> ciao
> Luca
> http://gis.cri.fmach.it/delucchi/
> www.lucadelu.org
