[GRASS-dev] temporal modules cannot open database
Vaclav Petras
wenzeslaus at gmail.com
Thu Jun 25 12:23:41 PDT 2015
On Thu, Jun 25, 2015 at 5:53 AM, Sören Gebbert <soerengebbert at googlemail.com
> wrote:
> Hi Luca,
> i just committed a patch in SVN that can handle modified location path's.
Thanks Soeren, I think I actually hit the issue before.
> Please make an update of grass7.1 and then call t.connect -d in the
> specific location/mapset to reset the default connection, which is
> mapset specific.
> I hope the temporal framework will find the correct database again.
> Best regards
> Soeren
> 2015-06-25 11:30 GMT+02:00 Luca Delucchi <lucadeluge at gmail.com>:
> > On 25 June 2015 at 00:05, Sören Gebbert <soerengebbert at googlemail.com>
> wrote:
> >> Hi Luca,
> > Hio Soeren
> >> is it possible that the path to the location has changed or that the
> >> location was renamed?
> > mmm I don't think so, but I'm not sure.
> > The path to db it seems correct using t.connect -l, do you have any
> > trick to solve this problem?
> >> Best regards
> >> Soeren
> > ciao
> > Luca
> > http://gis.cri.fmach.it/delucchi/
> > www.lucadelu.org
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150625/53485e70/attachment.html>
