[GRASS-dev] Weekly snapshot - link with non-changing name?
Rainer M Krug
Rainer at krugs.de
Fri Jun 26 01:52:13 PDT 2015
Hi Vaclav,
Vaclav Petras <wenzeslaus at gmail.com> writes:
> On Mon, Jun 22, 2015 at 9:40 AM, Rainer M Krug <Rainer at krugs.de> wrote:
>> Markus Neteler <neteler at osgeo.org> writes:
>> >> It is really just a automatic snapshot, not a tested
>> >> > release.
>> >> Thanks - so I will then use HEAD of the svn - easier to do in homebrew,
>> >> as no sha hash is needed of the downloaded file.
>> > You want me to generate that?
>> No - no need. I just tell homebrew to download head from svn and than to
>> compile it - it works.
>> I will post a link to the recipe later this week. This will make testing
>> of GRASS 7.1 easy on OS X.
> And it can be combined with:
> cd /grass/source/code/root
> ./bin.../grass71 ~/grassdata/nc_spm_08/PERMANENT/ \
> --exec python -m grass.gunittest.main \
> --location nc_spm_08 --location-type nc
That is a brilliant idea. But as the tests will be run automatically, I
need to download the data.
I assume this is the dataset to be used:
http://grass.osgeo.org/sampledata/north_carolina/nc_spm_08_grass7.tar.gz
Is this correct?
Rainer
> Thanks a lot,
>> Rainer
>> > Markus
>> >> Thanks,
>> >> Rainer
>> >> > Vaclav
>> >> > Thanks,
>> >> >> Rainer
>> >> >> > Rainer
>> >> >> >> Markus
>> >> >> Rainer M. Krug
>> >> >> email: Rainer<at>krugs<dot>de
>> >> >> PGP: 0x0F52F982
>> >> >> _______________________________________________
>> >> >> grass-dev mailing list
>> >> >> grass-dev at lists.osgeo.org
>> >> >> http://lists.osgeo.org/mailman/listinfo/grass-dev
>> >> Rainer M. Krug
>> >> PGP: 0x0F52F982
>> Rainer M. Krug
>> PGP: 0x0F52F982
Rainer M. Krug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150626/08326966/attachment.pgp>
