[GRASS-dev] Weekly snapshot - link with non-changing name?
Vaclav Petras wenzeslaus at gmail.com
Fri Jun 26 07:18:42 PDT 2015
On Fri, Jun 26, 2015 at 4:52 AM, Rainer M Krug <Rainer at krugs.de> wrote:
> Hi Vaclav,
> Vaclav Petras <wenzeslaus at gmail.com> writes:
> > On Mon, Jun 22, 2015 at 9:40 AM, Rainer M Krug <Rainer at krugs.de> wrote:
> >> Markus Neteler <neteler at osgeo.org> writes:
> >> >> It is really just a automatic snapshot, not a tested
> >> >> > release.
> >> >> Thanks - so I will then use HEAD of the svn - easier to do in
> homebrew,
> >> >> as no sha hash is needed of the downloaded file.
> >> > You want me to generate that?
> >> No - no need. I just tell homebrew to download head from svn and than to
> >> compile it - it works.
> >> I will post a link to the recipe later this week. This will make testing
> >> of GRASS 7.1 easy on OS X.
> > And it can be combined with:
> >     cd /grass/source/code/root
> >     ./bin.../grass71 ~/grassdata/nc_spm_08/PERMANENT/ \
> >         --exec python -m grass.gunittest.main \
> >         --location nc_spm_08 --location-type nc
> That is a brilliant idea. But as the tests will be run automatically, I
> need to download the data.
The download could be added to test execution but I'm not sure about that.
It would just make it more complex.
> I assume this is the dataset to be used:
> http://grass.osgeo.org/sampledata/north_carolina/nc_spm_08_grass7.tar.gz
> Is this correct?
Yes. Although, there are some inconsistencies (some test fail because they
expect the basic nc spm). However, this all should change because we should
switch to the new sample dataset naming scheme [1]. Needless to say,
volunteers needed.
Vaclav
[1] https://trac.osgeo.org/grass/wiki/SampleDataset
> Rainer
> > Thanks a lot,
> >> Rainer
> >> > Markus
> >> >> Thanks,
> >> >> Rainer
> >> >> > Vaclav
> >> >> > Thanks,
> >> >> >> Rainer
> >> >> >> > Rainer
> >> >> >> >> Markus
> >> >> >> Rainer M. Krug
> >> >> >> email: Rainer<at>krugs<dot>de
> >> >> >> PGP: 0x0F52F982
> >> >> >> _______________________________________________
> >> >> >> grass-dev mailing list
> >> >> >> grass-dev at lists.osgeo.org
> >> >> >> http://lists.osgeo.org/mailman/listinfo/grass-dev
> >> >> Rainer M. Krug
> >> >> PGP: 0x0F52F982
> >> Rainer M. Krug
> >> PGP: 0x0F52F982
> Rainer M. Krug
> PGP: 0x0F52F982
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150626/cf2898f4/attachment.html>
