[GRASS-dev] raster digitizer
Anna Petrášová
kratochanna at gmail.com
Wed Mar 4 10:36:14 PST 2015
On Wed, Mar 4, 2015 at 12:49 PM, Paulo van Breugel <p.vanbreugel at gmail.com>
wrote:
> When editing a raster using the raster digitizer, the resolution is
> changes (lower resolution) after saving the edits. Is this the intended
> behaviour, and if so, what is determining the resolution?
> My prefered behaviour would be that the resolution used follows that of
> the region settings.
Hm, that's how it should behave. Are you sure it's not doing that? I don't
change region anywhere in the code so it must use the computational region.
Anna
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150304/20860391/attachment.html>
