[GRASS-dev] raster digitizer
Paulo van Breugel
p.vanbreugel at gmail.com
Wed Mar 4 11:07:54 PST 2015
Hi Anna,
OK, I did some further testing in another mapset, and it seems it was a
problem with the region settings. After setting the region using 'set
computational region from selected map(s)' the region wasn't set correctly.
It seems to work fine now though. Sorry for the buzz.
On Wed, Mar 4, 2015 at 7:36 PM, Anna Petrášová <kratochanna at gmail.com>
wrote:
> On Wed, Mar 4, 2015 at 12:49 PM, Paulo van Breugel <p.vanbreugel at gmail.com
> > wrote:
>> When editing a raster using the raster digitizer, the resolution is
>> changes (lower resolution) after saving the edits. Is this the intended
>> behaviour, and if so, what is determining the resolution?
>> My prefered behaviour would be that the resolution used follows that of
> Hm, that's how it should behave. Are you sure it's not doing that? I don't
> change region anywhere in the code so it must use the computational region.
> Anna
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150304/354c6d70/attachment.html>
