[GRASS-dev] raster digitizer
Anna Petrášová kratochanna at gmail.com
Wed Mar 4 11:12:43 PST 2015
On Wed, Mar 4, 2015 at 2:07 PM, Paulo van Breugel <p.vanbreugel at gmail.com>
wrote:
> Hi Anna,
> OK, I did some further testing in another mapset, and it seems it was a
> problem with the region settings. After setting the region using 'set
> computational region from selected map(s)' the region wasn't set correctly.
> It seems to work fine now though. Sorry for the buzz.
> no problem
Anna
> On Wed, Mar 4, 2015 at 7:36 PM, Anna Petrášová <kratochanna at gmail.com>
> wrote:
>> On Wed, Mar 4, 2015 at 12:49 PM, Paulo van Breugel <
>> p.vanbreugel at gmail.com> wrote:
>>> When editing a raster using the raster digitizer, the resolution is
>>> changes (lower resolution) after saving the edits. Is this the intended
>>> behaviour, and if so, what is determining the resolution?
>>> My prefered behaviour would be that the resolution used follows that of
>> Hm, that's how it should behave. Are you sure it's not doing that? I
>> don't change region anywhere in the code so it must use the computational
>> region.
>> Anna
>>> grass-dev mailing list
>>> grass-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150304/6e26bc4d/attachment-0001.html>
