[GRASS-dev] [GRASS GIS] #2616: grass.script.array cannot write raster
GRASS GIS trac at osgeo.org
Sun Mar 8 23:46:23 PDT 2015
 Reporter:  annakrat     |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  critical     |   Milestone:  7.0.1
Component:  Python       |     Version:  svn-trunk
 Keywords:  array        |    Platform:  All
      Cpu:  Unspecified  |
Comment(by glynn):
 Replying to [ticket:2616 annakrat]:
 > It seems the r64426 (backported in r64614) broke writing the array.
 > Tested [http://grass.osgeo.org/grass70/manuals/libpython/script.html
 example] with 1.8.2 !NumPy, the temporary file disappears once calling
 this line:
 It appears that __del__ gets called on the original array instance for
 every slice. Note that changing `map2d_1[y][x]=` to `map2d_1[y,x]=` (which
 is to be preferred) avoids the issue, but there are situations where
 slicing will be appropriate, so this needs to be dealt with.
 The docstring for numpy.memmap says:
     This subclass of ndarray has some unpleasant interactions with
     some operations, because it doesn't quite fit properly as a subclass.
 r64819 wraps the temporary file in an object, avoiding the need for a
 __del__ method in the array/array3d class. This appears to solve the
 issue.
 r64820 fixes the examples to use multi-dimensional indexing rather than
 slicing.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2616#comment:1>
