[GRASS-dev] [GRASS GIS] #2080: wxGUI: changing properties of barscale or legend
GRASS GIS trac at osgeo.org
Mon Mar 9 12:30:16 PDT 2015
  Reporter:  martinl      |       Owner:  grass-dev@…
      Type:  enhancement  |      Status:  closed
  Priority:  normal       |   Milestone:  7.0.0
 Component:  wxGUI        |     Version:  svn-trunk
Resolution:  fixed        |    Keywords:  decorations, d.barscale, d.legend, d.northarrow
  Platform:  All          |         Cpu:  All
Changes (by wenzeslaus):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Replying to [comment:13 martinl]:
 > Replying to [comment:12 annakrat]:
 > > > much much more better! There is only one limitation - you cannot add
 multiple barscales, legends, or northarrows, right?
 > > Yes, but this limitation was there even before. The workaround is to
 add the command layer which then behaves little differently (no moving
 around). But I guess this is not the common requirement.
 > right, the correct sentence is "There is *still* one limitation".
 Original issue is solved. Closing.
 Please, open a new enhancement ticket if you want track this limitation.
 See also
 [wiki:GSoC/2015#CompletebasiccartographysuiteinGRASSGISwxGUIMapDisplay
 GSoC 2015] ideas page.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2080#comment:14>
