[GRASS-dev] "Complete basic cartography suite in GRASS GIS wxGUI Map Display"
Dp Docs
sdpan21 at gmail.com
Mon Mar 9 14:38:21 PDT 2015
Sir, I am getting one problem while accessing the subversion repo. Can you
please help me with this?
the problem is attached in this email.
Thanks
Durgesh Pandey.
On Tue, Mar 10, 2015 at 2:49 AM, Dp Docs <sdpan21 at gmail.com> wrote:
> Thank you sir for such a nice response. I will look forward to work on
> this.
> Thanks again
> Durgesh Pandey.
> On Tue, Mar 10, 2015 at 2:41 AM, Vaclav Petras <wenzeslaus at gmail.com>
> wrote:
>> On Mon, Mar 9, 2015 at 4:12 PM, Dp Docs <sdpan21 at gmail.com> wrote:
>>> I would like to work on this " Add background color to d.legend.". Can
>>> you please provide some approach and repository related to problem.
>> Once you have GRASS GIS source code from Subversion repository [1], you
>> will find d.legend source code in `display/d.legend` directory [2]. You
>> should compile GRASS GIS, so you have everything you need for development
>> [3].
>> d.legend is using GRASS Display library [4]. It would be best if you find
>> some display (d.*) module which is already drawing some rectangle, polygon
>> or area and get inspiration from there.
>> Please keep communication on the mailing list so other can contribute or
>> read it too.
>> Vaclav
>> [1] http://trac.osgeo.org/grass/wiki/DownloadSource
>> [2] http://trac.osgeo.org/grass/browser/grass/trunk/display/d.legend
>> [3] http://trac.osgeo.org/grass/wiki/GSoC/2015#Tipsforstudents
>> [4] http://grass.osgeo.org/programming7/displaylib.html
>>> Durgesh Pandey.
>>> On Tue, Mar 10, 2015 at 1:36 AM, Vaclav Petras <wenzeslaus at gmail.com>
>>> wrote:
>>>> On Mon, Mar 9, 2015 at 4:33 AM, Dp Docs <sdpan21 at gmail.com> wrote:
>>>> > Hi,
>>>> > I Am an undergrad. student from IIIT Hyderabad,India. I believe I have
>>>> > good Programming Knowledge in languages like Python, C/C++. I have
>>>> > Already Done Some Projects in these Languages. I have practical
>>>> > knowledge in wxPython. I want to work on this Project as a pat of GSOC
>>>> > 2015.
>>>> Hi,
>>>> this sounds great. As you perhaps noticed students are encouraged [1]
>>>> to show their skills by contributing to the project before applications are
>>>> evaluated. OSGeo recommends [2] to do some bug fixing or implementation of
>>>> small features. You can even try to implement some smaller things from the
>>>> GSoC idea itself [3]. I selected some options which might be appropriate:
>>>> * Store legend, scale bar, north arrow and text (and potentially others
>>>> objects if added) in the workspace (ticket #2369).
>>>> * Add units to legend as parameter to d.legend. Optionally add also
>>>> title and description. Optionally also put units after each number, not
>>>> just to one place in title area as it is now.
>>>> * Add possibility to add any image to Map Display (as in Animation
>>>> Tool, `g.gui.animation`). Use cases are organization logo and overview maps
>>>> (insets).
>>>> * Add background color to d.legend. Currently the legend has
>>>> transparent background. Background rectangle should include all parts of
>>>> the legend including (possible) title. Additional features include rounded
>>>> corners, border and opacity settings.
>>>> You can select whatever you want but it should be something you are
>>>> actually able to finish soon. You can also browse through bug tracker,
>>>> components wxGUI and Dispaly [5, 6], to see other options to select from.
>>>> Vaclav
>>>> [1]
>>>> http://wiki.osgeo.org/wiki/Google_Summer_of_Code_Recommendations_for_Students
>>>> [2] http://lists.osgeo.org/pipermail/soc/2015-March/002908.html
>>>> [3]
>>>> http://trac.osgeo.org/grass/wiki/GSoC/2015#CompletebasiccartographysuiteinGRASSGISwxGUIMapDisplay
>>>> [4] http://trac.osgeo.org/grass/ticket/2369
>>>> [5]
>>>> http://trac.osgeo.org/grass/query?status=assigned&status=new&status=reopened&component=wxGUI&order=priority&col=id&col=summary&col=status&col=type&col=priority&col=milestone&col=component
>>>> [6]
>>>> http://trac.osgeo.org/grass/query?status=assigned&status=new&status=reopened&component=Display&order=priority&col=id&col=summary&col=component&col=status&col=type&col=priority&col=milestone
>>>> > I want to know whether someone is already committed to this
>>>> > Project or not? I also want to know how to get the mentor's contact
>>>> > regarding this Project. I have some Technical Doubts which I would
>>>> > like to ask them.
>>>> > Thanks
>>>> > Durgesh Pandey.
>>>> > _______________________________________________
>>>> > grass-dev mailing list
>>>> > grass-dev at lists.osgeo.org
>>>> > http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150310/73fcdafd/attachment-0001.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150310/73fcdafd/attachment-0001.obj>
