[GRASS-dev] "Complete basic cartography suite in GRASS GIS wxGUI Map Display"
Dp Docs
sdpan21 at gmail.com
Mon Mar 9 14:19:32 PDT 2015
Thank you sir for such a nice response. I will look forward to work on
this.
Thanks again
Durgesh Pandey.
On Tue, Mar 10, 2015 at 2:41 AM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Mon, Mar 9, 2015 at 4:12 PM, Dp Docs <sdpan21 at gmail.com> wrote:
>> I would like to work on this " Add background color to d.legend.". Can
>> you please provide some approach and repository related to problem.
> Once you have GRASS GIS source code from Subversion repository [1], you
> will find d.legend source code in `display/d.legend` directory [2]. You
> should compile GRASS GIS, so you have everything you need for development
> [3].
> d.legend is using GRASS Display library [4]. It would be best if you find
> some display (d.*) module which is already drawing some rectangle, polygon
> or area and get inspiration from there.
> Please keep communication on the mailing list so other can contribute or
> read it too.
> Vaclav
> [1] http://trac.osgeo.org/grass/wiki/DownloadSource
> [2] http://trac.osgeo.org/grass/browser/grass/trunk/display/d.legend
> [3] http://trac.osgeo.org/grass/wiki/GSoC/2015#Tipsforstudents
> [4] http://grass.osgeo.org/programming7/displaylib.html
>> Durgesh Pandey.
>> On Tue, Mar 10, 2015 at 1:36 AM, Vaclav Petras <wenzeslaus at gmail.com>
>> wrote:
>>> On Mon, Mar 9, 2015 at 4:33 AM, Dp Docs <sdpan21 at gmail.com> wrote:
>>> > Hi,
>>> > I Am an undergrad. student from IIIT Hyderabad,India. I believe I have
>>> > good Programming Knowledge in languages like Python, C/C++. I have
>>> > Already Done Some Projects in these Languages. I have practical
>>> > knowledge in wxPython. I want to work on this Project as a pat of GSOC
>>> > 2015.
>>> Hi,
>>> this sounds great. As you perhaps noticed students are encouraged [1] to
>>> show their skills by contributing to the project before applications are
>>> evaluated. OSGeo recommends [2] to do some bug fixing or implementation of
>>> small features. You can even try to implement some smaller things from the
>>> GSoC idea itself [3]. I selected some options which might be appropriate:
>>> * Store legend, scale bar, north arrow and text (and potentially others
>>> objects if added) in the workspace (ticket #2369).
>>> * Add units to legend as parameter to d.legend. Optionally add also
>>> title and description. Optionally also put units after each number, not
>>> just to one place in title area as it is now.
>>> * Add possibility to add any image to Map Display (as in Animation Tool,
>>> `g.gui.animation`). Use cases are organization logo and overview maps
>>> (insets).
>>> * Add background color to d.legend. Currently the legend has transparent
>>> background. Background rectangle should include all parts of the legend
>>> including (possible) title. Additional features include rounded corners,
>>> border and opacity settings.
>>> You can select whatever you want but it should be something you are
>>> actually able to finish soon. You can also browse through bug tracker,
>>> components wxGUI and Dispaly [5, 6], to see other options to select from.
>>> Vaclav
>>> [1]
>>> http://wiki.osgeo.org/wiki/Google_Summer_of_Code_Recommendations_for_Students
>>> [2] http://lists.osgeo.org/pipermail/soc/2015-March/002908.html
>>> [3]
>>> http://trac.osgeo.org/grass/wiki/GSoC/2015#CompletebasiccartographysuiteinGRASSGISwxGUIMapDisplay
>>> [4] http://trac.osgeo.org/grass/ticket/2369
>>> [5]
>>> http://trac.osgeo.org/grass/query?status=assigned&status=new&status=reopened&component=wxGUI&order=priority&col=id&col=summary&col=status&col=type&col=priority&col=milestone&col=component
>>> [6]
>>> http://trac.osgeo.org/grass/query?status=assigned&status=new&status=reopened&component=Display&order=priority&col=id&col=summary&col=component&col=status&col=type&col=priority&col=milestone
>>> > I want to know whether someone is already committed to this
>>> > Project or not? I also want to know how to get the mentor's contact
>>> > regarding this Project. I have some Technical Doubts which I would
>>> > like to ask them.
>>> > Thanks
>>> > Durgesh Pandey.
>>> > _______________________________________________
>>> > grass-dev mailing list
>>> > grass-dev at lists.osgeo.org
>>> > http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150310/c61a442b/attachment-0001.html>
