[GRASS-dev] compile gdal with grass
Michel Wortmann wortmann at pik-potsdam.de
Wed Mar 11 01:58:03 PDT 2015
Hi Martin and list,
would it be possible to reflect these changes in the Ubuntu packages on
the gdal launchpad (ubuntugis-unstable) and making them compatible with
the grass7 packages?
I tried building gdal 1.11.2 --with-grass against preinstalled grass7
packages (Ubuntu 14.04), but the grass7 (and qgis for that matter) are
still depending on gdal-1.11.1. Now just to be able to browse the GRASS
database in QGIS it would make it necessary to build all three from
source. Or are there any ideas on avoiding that? The gdal-grass plugin
unfortunately doesnt work with grass-7.
Thanks,
Michel
On 01/07/2015 12:51 PM, Paulo van Breugel wrote:
> Hi Martin, just recompiled GDAL against GRASS, and I can confirm it
> works. Thanks for the fix!
> On Mon, Jan 5, 2015 at 3:50 PM, Martin Landa <landa.martin at gmail.com
> <mailto:landa.martin at gmail.com>> wrote:
>     Hi,
>     2015-01-05 15:32 GMT+01:00 Markus Neteler <neteler at osgeo.org
>     <mailto:neteler at osgeo.org>>:
>     > On Mon, Jan 5, 2015 at 12:56 PM, Martin Landa
>     <landa.martin at gmail.com <mailto:landa.martin at gmail.com>> wrote:
>     >> these errors are related to the recent API changes in GRASS 7.
>     I fixed
>     >> that in gdal trunk [1] and later will do backport it to gdal 1.11
>     >> branch.
>     done in r28291. To compile GDAL against GRASS you need at least GDAL
>     1.11 from svn branch [1].
>     Martin
>     [1] http://svn.osgeo.org/gdal/branches/1.11/
>     Martin Landa
>     http://geo.fsv.cvut.cz/gwiki/Landa
>     http://gismentors.eu/mentors/landa
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150311/82e6d657/attachment-0001.html>
