[GRASS-dev] GSOC project proposal
Vaclav Petras wenzeslaus at gmail.com
Wed Mar 11 18:16:53 PDT 2015
On Wed, Mar 11, 2015 at 11:36 AM, sarthak agarwal <sarthak0415 at gmail.com>
wrote:
> I have used Grass directly installing from the ppa .. I was trying to
compile it from the source and i'm getting error .Below is the error.log
content.
> > GRASS GIS 7.0.1svn r64826 compilation log
Note that for development you will need trunk, not release branch.
> > Errors in:
> > /home/sarthak/grass-7.0.svn/display/d.path
> > /home/sarthak/grass-7.0.svn/display/d.vect
> > /home/sarthak/grass-7.0.svn/vector/v.neighbors
> > /home/sarthak/grass-7.0.svn/ps/ps.map
> > In case of errors please change into the directory with error and run
'make'.
> > If you get multiple errors, you need to deal with them in the order they
> > appear in the error log. If you get an error building a library, you
will
> > also get errors from anything which uses the library.
What compilation guide have you used? What it is saying when you do what it
wants?
> Can you please suggest me a way to solve it. Also i was looking for
r.in.proj' folder in the source code but couldn't find it . It was there on
the link you send but not on the svn repo. Should i directly copy the files
from there to the local repo.
These two modules are in addons. Compare the SVN repo with the Trac URLs
and you will find how to get them.
>> Source code for r.in.proj and v.in.proj:
>> https://trac.osgeo.org/grass/browser/grass-addons/grass7/raster/r.in.proj
>> https://trac.osgeo.org/grass/browser/grass-addons/grass7/vector/v.in.proj
Please, stay on mailing list.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150311/a6b7a855/attachment.html>
