[GRASS-dev] r.to.rast3
Paulo van Breugel p.vanbreugel at gmail.com
Tue Mar 17 01:45:59 PDT 2015
On the manual page for r.to.rast3, under Notes, it says "If fewer 2D raster
maps are provided than depths, the last give 2D map is used to fill up the
RASTER3D slices to the top". How do you define the depths?
Perhaps related, in Example 2 it says that it "shows how to convert 3 maps
into 3d map with 6 layers". Why 6 layers, what determines that 6 layers are
created?
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150317/31213df7/attachment.html>
