[GRASS-dev] Linke turbidity in r.sun.daily
Nikos Alexandris
nik at nikosalexandris.net
Sat Mar 21 11:24:58 PDT 2015
Nikos Alexandris <nik at nikosalexandris.net wrote:
>> While working on the script, I'd like to understand if the
>> "gisprompt" line is correct:
>> #%option
>> #% key: linke
>> #% key_desc: key description here
>> #% type: string
>> #% label: label here
>> #% gisprompt: old,fcell,raster
>> #% description: Name of the Linke atmospheric turbidity coefficient
>> input
>> raster map
>> #% required : no
>> #%end
Vaclav Petras wrote:
> This does not seem correct. Run
> r.sun --script
Hmm, ok. Still, why "cell" for Linke-T? Linke-Ts are floats.
> and you will get what should be there. But note that the output is
> suboptimal because it is listing all the details and it is not using
> standard options, so look which standard options you can use (e.g.
> OPT_R_INPUT).
I will try.
> It would be good if you can look to r.sun which other options you can
> include.
I am. I am also renaming stuff, eg slope_in to slope. I guess this is
wanted.
Nikos
> According to <http://wgrass.media.osaka-cu.ac.jp/grassh/programming7/
>> gislib_cmdline_parsing.html#gisprompt_Member>:
>> "...three comma-separated (no spaces allowed) sub-arguments..." and
>> "Second argument: ...should be the name of one of the standard
>> subdirectories of the mapset, as listed in
>> $GISBASE/etc/element_list."
>> Since Linke Turbidity ranges in [0, 7.0], "fcell" shoulb be correct
>> here.
>> Also, does it matter if a map is DCELL or FCELL, regarding the
>> "element"?
>> Either will be stored inside the "fcell" directory, right?
