[GRASS-dev] GSOC project proposal: GUI plugin system for GRASS GIS
jyoti misra
jyotimisra.99 at gmail.com
Tue Mar 24 23:20:09 PDT 2015
Hello,
Sorry for the late reply. I was busy with exams last week.
I compiled the code from source, read a tutorial on grass gis and I am
fairly comfortable with grass environment.
I was looking into the Bug: "Quotes not preserved in command after pressing
enter in GUI command console" and tried it out on my machine. I was trying
to fix it and I think most probably it's some problem with regex search
which is deleting the quotes from the command.
I was looking into the code for fixing the bug but couldn't find the
relevant file to change. Could you please guide me with that.
Also for the enhancement: "Button, documentation and perhaps something more
interactive for finding EPSG codes online rather then in GRASS GIS list" I
was thinking of more interactive process of using EPSG -
1. We can merge epsg.io code into our existing structure. http://epsg.io/
2. We can add a button that will redirect users to epsg.io
I would like to have your suggestions on the same
I know I am running a bit late with the bug fixing but I can assure you I
won't disappoint you during the course of project.
I am very interested in doing GSOC under grass org as it will be an added
advantage to my ongoing research in computer science and spatial
informatics. I would be thankful if you could help me with submitting GSOC
proposal.
Regards
Jyoti
On Thu, Mar 12, 2015 at 9:10 AM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> Hello.
> On Tue, Mar 10, 2015 at 3:46 PM, jyoti misra <jyotimisra.99 at gmail.com>
> wrote:
> > Dear Sir/Madam,
> > Myself Jyoti currently working under Dr. KS Rajan as a research student
> in Spatial Informatics Lab, IIIT hyderabad . I am currently working in Land
> Use modelling of Barrack valley region. Previously i have worked on
> Billboard placement optimization problem considering the spatial ,temporal
> and traffic features.
> > I am interested in working with grass org under the project "GUI plugin
> system for GRASS GIS". The project is interesting and I have some idea of
> the technologies requires for the project as i have already worked in
> Python , c/c++.
> Good. Now you should find some enhancements or bugs in GRASS GIS bug
> tracker [1] and implement or fix them before the application evaluation to
> show level of you proficiency [2, 3].
> You can also select from this list:
> Enhancement: Let users save/load SQL statements in wxGUI attribute table
> manager
> http://trac.osgeo.org/grass/ticket/1205
> Bug: Quotes not preserved in command after pressing enter in GUI command
> console
> http://trac.osgeo.org/grass/ticket/1435
> http://trac.osgeo.org/grass/ticket/1437
> Enhancement: Store map elements such as legend, text and scale bar in
> workspace file.
> http://trac.osgeo.org/grass/ticket/2484
> Enhancement: Possibility to automatically load last used workspace when
> GRASS GIS GUI starts
> http://trac.osgeo.org/grass/ticket/2604
> Enhancement: Store recently used workspaces and offer them in the menu
> Enhancement: Implement georeferenced image output for "Save display..."
> function in GUI and d.out.file module (and its wxGUI implementation)
> http://trac.osgeo.org/grass/ticket/977
> Bug: Undefined settings variable issue in bivariate scatterplot tool
> http://trac.osgeo.org/grass/ticket/2247
> Enhancement: Button, documentation and perhaps something more interactive
> However, you can explore the open issues on GRASS GIS bug tracker
> yourself. Just keep in mind that this GSoC project would be in Python and
> wxPython. You can attempt to solve more of these tasks, the more the
> better. In any case, the thing you select and do should be in Python and
> should sufficiently represent your skills. Draft implementation of non-GUI
> (model) part of the plugin system would be helpful to understand the issues
> which you should address in the application.
> In any case, start with compiling GRASS GIS from source code (trunk) from
> Subversion repository [4], reading tips for students [5] and going through
> instructions for other students [6, 7] (you can use Nabble [8] for that).
> Also read Submitting rules [9] and how-to [10] for wxGUI development. Also
> learn how to do basic tasks in GRASS GIS graphical user interface (called
> wxGUI), use e.g. GRASS wiki or the manual as learning resource.
> Please, always create a new thread on mailing list for distinct topics.
> Best,
> Vaclav
> [1] https://trac.osgeo.org/grass/query
> [2]
> http://wiki.osgeo.org/wiki/Google_Summer_of_Code_Recommendations_for_Students
> [3] http://lists.osgeo.org/pipermail/soc/2015-March/002908.html
> [4] http://trac.osgeo.org/grass/wiki/DownloadSource
> [5] http://trac.osgeo.org/grass/wiki/GSoC/2015#Tipsforstudents
> [6] http://lists.osgeo.org/pipermail/grass-dev/2015-March/074420.html
> [7] http://lists.osgeo.org/pipermail/grass-dev/2015-March/074433.html
> [8] http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
> [9] http://trac.osgeo.org/grass/wiki/Submitting/wxGUI
> [10] http://grasswiki.osgeo.org/wiki/WxGUI_Programming_Howto
> > Please guide me in the project and provide some docs and links where i
> can proceed with solving it. Also I want to know whether someone is already
> committed to this Project or not?
> > Regards,
> > Jyoti Misra
> > Btech and Ms by research in Spatial Informatics
> > International Institute Of Information Technology ,Hyderabad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150325/67e90db0/attachment.html>
