[GRASS-dev] gis.py:801: DeprecationWarning: classic int division
Anna Petrášová kratochanna at gmail.com
Sat May 2 06:21:31 PDT 2015
On Sat, May 2, 2015 at 8:13 AM, Nikos Alexandris <nik at nikosalexandris.net>
wrote:
> I just ran
> python -Qwarn -tt -3
> on a custom python script and the first line returned is
> Is this something that needs to be fixed?
in Python 2 :
1 / 2
results in 0, that's 'classic int division'
in Python 3 it results in 0.5
so it warns you that you are using 'classic int division' so in Python 3
this will change result. So depending on what you want, either use
float(1)/2
or to keep the integer division
from __future__ import division
1//2
> Nikos
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150502/3d646477/attachment.html>
