[GRASS-dev] gis.py:801: DeprecationWarning: classic int division
Mon May 4 14:04:47 PDT 2015
Nikos Alexandris wrote:
> I just ran
> python -Qwarn -tt -3
> on a custom python script and the first line returned is
> Is this something that needs to be fixed?
That specific warning relates to code which is generated by ctypesgen
from system headers. Specifically, the definition of __sigset_t in
<sigset.h>:
	# define _SIGSET_NWORDS	(1024 / (8 * sizeof (unsigned long int)))
	typedef struct
	    unsigned long int __val[_SIGSET_NWORDS];
	  } __sigset_t;
is translated to:
	# /usr/include/bits/sigset.h: 30
	class struct_anon_11(Structure):
	    pass
	struct_anon_11.__slots__ = [
	    '__val',
	struct_anon_11._fields_ = [
	    ('__val', c_ulong * (1024 / (8 * sizeof(c_ulong)))),
	__sigset_t = struct_anon_11 # /usr/include/bits/sigset.h: 30
The reason this is ending up in gis.py is for the definition of
jmp_buf which is used by G_fatal_longjmp().
As that function is (probably) unusable from Python, we could probably
just guard the declaration with "#ifndef CTYPESGEN".
But that may not be the only such issue.
For compatibility with Python 3, we need to add
	from __future__ import division
and use "//" for integer (truncating) division. But IIRC, that
requires Python 2.7. If GRASS still works with 2.6, it's not worth
abandonding support for it over this issue, given that there are
almost certainly far more significant issues with Python 3
compatibility (such as its insistence on coercing everything to
Unicode).
