[GRASS-dev] Testing an add-on from sandbox before moving to grass-addons
Vaclav Petras wenzeslaus at gmail.com
Tue May 5 05:51:06 PDT 2015
On Tue, May 5, 2015 at 8:41 AM, Nikos Alexandris <nik at nikosalexandris.net>
wrote:
> * Martin Landa <landa.martin at gmail.com> [2015-05-05 13:41:32 +0200]:
> > 2015-05-05 13:42 GMT+02:00 Nikos Alexandris <nik at nikosalexandris.net>:
> > >> it's not possible, to enable installing this extension via
> > >> g.extension, you need to move this extension to `grass7/imagery`.
> > > Thanks Martin.  Is grass7/imagery the safest place to move into?  Just
> > > to confirm.
> > yes, as grass7/imagery/i.fusion.hpf. Use `svn move` to do this job.
Martin
> Noted, thank you for your time.
You need to `svn checkout` the whole repository for this operation. At
least this is what I have (grass-addons for work in addons but also the
whole repo for these moves).
> Nikos
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150505/5a007ae9/attachment.html>
