[GRASS-dev] Testing an add-on from sandbox before moving to grass-addons
Nikos Alexandris nik at nikosalexandris.net
Wed May 6 05:44:36 PDT 2015
* Vaclav Petras <wenzeslaus at gmail.com> [2015-05-05 08:51:06 -0400]:
> On Tue, May 5, 2015 at 8:41 AM, Nikos Alexandris <nik at nikosalexandris.net>
> wrote:
> > * Martin Landa <landa.martin at gmail.com> [2015-05-05 13:41:32 +0200]:
> > > 2015-05-05 13:42 GMT+02:00 Nikos Alexandris <nik at nikosalexandris.net>:
> > > >> it's not possible, to enable installing this extension via
> > > >> g.extension, you need to move this extension to `grass7/imagery`.
> > > > Thanks Martin.  Is grass7/imagery the safest place to move into?  Just
> > > > to confirm.
> > > yes, as grass7/imagery/i.fusion.hpf. Use `svn move` to do this job.
> Martin
> > Noted, thank you for your time.
> You need to `svn checkout` the whole repository for this operation. At
> least this is what I have (grass-addons for work in addons but also the
> whole repo for these moves).
So, you folks keep a complete copy of it locally?  Isn't it big?
Nikos
