[GRASS-dev] [GRASS GIS] #2656: GRASS freezes for 5-10 mins before eventually showing attribute table
trac at osgeo.org
Sun May 10 22:21:56 PDT 2015
Reporter: richardc | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.0.1
Component: wxGUI | Version: svn-releasebranch70
Resolution: | Keywords: attribute table, postgresql
CPU: x86-64 | Platform: Linux
Comment (by richardc):
I was wondering if anyone might have any suggestions on how to resolve
this issue.
For instance, in addition to GRASS freezing on trying to show the
attribute table, the same is observed with db.describe or db.columns when
selected from the Layer Manager GUI. I have to restart GRASS each time if
I inadvertently select the these commands.
e.g.,
Database > Database information > Describe table [db.describe]
I am however, able to list database tables:
db.tables -p
public.bnd_cahpa_f1apr_05216_nc_remapped_nc_1
public.bnd_cahpa_f1apr_05216_nc_remapped_nc_10
public.bnd_cahpa_f1apr_05216_nc_remapped_nc_11
public.bnd_cahpa_f1apr_05216_nc_remapped_nc_12
I notice one error in the following:
(Mon May 11 11:49:23 2015)
db.test --verbose test=test1
Using DB driver: pg
EXECUTE: OK
EXECUTE: OK
EXECUTE: OK
EXECUTE: OK
RESULT: OK
EXECUTE: OK
RESULT: OK
EXECUTE: OK
EXECUTE: OK
EXECUTE: OK
EXECUTE: OK
ERROR: RESULT: ******** ERROR ********
EXECUTE: OK
2d1
< 3|0|_\\'_|
3a3
> 3|0|_\'_|
CREATE TABLE grass_test1 (i1 INTEGER, d1 DOUBLE PRECISION, c1 VARCHAR(20))
INSERT INTO grass_test1 VALUES ( 1, 123.456, 'abcd' )
INSERT INTO grass_test1 VALUES ( 2, null, 'xxx' )
SELECT * FROM grass_test1
SELECT c1 FROM grass_test1 WHERE d1 < 500 / 2 AND i1 <> 2 AND c1 LIKE
'%bc%'
INSERT INTO grass_test1 VALUES ( 3, 0.0, '_\''_' )
ALTER TABLE grass_test1 ADD COLUMN i2 INTEGER
UPDATE grass_test1 SET d1 = 18.6, i2 = 987 WHERE i1 = 2
DROP TABLE grass_test1
Ticket URL: <https://trac.osgeo.org/grass/ticket/2656#comment:4>
