[GRASS-dev] t.connect test for rasters takes over 3 hours to execute
Vaclav Petras
wenzeslaus at gmail.com
Mon May 11 06:52:00 PDT 2015
when I run t.connect test test_distr_tgis_db_raster.py [0] in Piemonte
Location [1], it takes 3.5 hours to complete [2]. This is happening
constantly for a long time already [3]. There is nothing in the outputs
which would indicate anything like this. Any ideas?
In case you wonder how different data influence the time, then you can see
run in NC SPM Location [4] and in an empty XY Location [5]. Also, similar
tests for 3D raster and vector data are fine [6, 7].
Is somebody able to reproduce that behavior or determine why it is
happening?
Thanks,
Vaclav
[0]
http://trac.osgeo.org/grass/browser/grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster.py
[1] http://grass.osgeo.org/download/sample-data/
[2]
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-05-11-07-00/report_for_piemonte_utm32_wgs84_grass7_stdmaps/temporal/t.connect/test_distr_tgis_db_raster/index.html
[3]
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2014-10-02-07-00/report_for_piemonte_utm32_wgs84_grass7_stdmaps/temporal/t.connect/test_distr_tgis_db_raster/index.html
[4]
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-05-11-07-00/report_for_nc_spm_08_grass7_nc/temporal/t.connect/test_distr_tgis_db_raster/index.html
[5]
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-05-11-07-00/report_for_empty_xy_all/temporal/t.connect/test_distr_tgis_db_raster/index.html
[6]
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-05-11-07-00/report_for_piemonte_utm32_wgs84_grass7_stdmaps/temporal/t.connect/test_distr_tgis_db_raster3d/index.html
[7]
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-05-11-07-00/report_for_piemonte_utm32_wgs84_grass7_stdmaps/temporal/t.connect/test_distr_tgis_db_vector/index.html
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150511/ba673b0a/attachment.html>
