[GRASS-dev] [GRASS GIS] #2675: r.in.gdal -e should set region to newly imported map
GRASS GIS trac at osgeo.org
Tue May 12 02:03:42 PDT 2015
 Reporter:  volcan01010       |      Owner:  grass-dev@…
     Type:  enhancement       |     Status:  new
 Priority:  minor             |  Milestone:  7.0.1
Component:  Raster            |    Version:  7.0.0
 Keywords:  r.in.gdal region  |        CPU:  Unspecified
 Platform:  Linux             |
 When running r.in.gdal with the -e flag (to update the region from the
 imported raster extents), the command finishes by setting the region to
 the default setting (even if that was not the previous setting).
 It may be preferable for it to set the region to match the newly imported
 map, so that follow up operations e.g. r.composite are run with the
 correct settings.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2675>
