[GRASS-dev] inconsistency between G_OPT_V_INPUT and G_OPT_R_INPUT
Pietro peter.zamb at gmail.com
Tue May 12 23:03:04 PDT 2015
Dear all,
I found an inconsistency of behaviors between G_OPT_R_INPUT and
G_OPT_V_INPUT, here the test code:
#!/usr/bin/env python
# -- coding: utf-8 --
#%module
#% description: Test
#% keywords: test
#%end
#%option G_OPT_R_INPUT
#% key: discharge
#% description: Name of river discharge [m3/s]
#% required: yes
#%end
#%option G_OPT_V_INPUT
#% key: river
#% key_desc: name
#% description: Name of vector map with interested segments of rivers
#% required: yes
#%end
from __future__ import print_function
import sys
# import grass libraries
from grass.script import core as gcore
def main(opts, flgs):
    print(opts, flgs)
if __name__ == "__main__":
    options, flags = gcore.parser()
    sys.exit(main(options, flags))
here is the output of the manual page:
python r.example.py --help
Description:
 Test
Keywords:
 test
Usage:
 r.example.py discharge=name river=name [--help] [--verbose] [--quiet]
   [--ui]
Flags:
 --h   Print usage summary
 --v   Verbose module output
 --q   Quiet module output
 --ui  Force launching GUI dialog
Parameters:
  discharge   Name of river discharge [m3/s]
      river   Name of input vector map
As you can see the description of the parameter add the default
description set in G_OPT_V_INPUT and in a new line the description
added manually in the definition of the module parameters. Instead the
G_OPT_R_INPUT shows only the description set manually.
The behavior concerning the GUI is worst, because it shows only the
default description string, see attached figure.
What do you think?
Pietro
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150513/64df8018/attachment-0001.png>
