[GRASS-dev] new rendering
Martin Landa
landa.martin at gmail.com
Fri May 15 00:23:20 PDT 2015
Hi Anna,
2015-05-15 5:05 GMT+02:00 Anna Petrášová <kratochanna at gmail.com>:
> are some problems I encountered in case you are not aware of them:
> - legend (overlays) doesn't show up, no error
> - dragging layers causes error
> - MapSwipe doesn't work - due to calls layer.Render() but it requires
> parameter environment. There are actually several of these calls in
> render.py, I was not sure what to do, maybe some of them can be just
> removed.
> - Vector digitizer and 3D view have some issues
> I will try to help as soon as I better understand the changes. Thank you!
thanks for reporting these issues. I will try to look at them ASAP
(first of all I want to fix multiple calling of `g.pnmcomp`). Then
there is also issue when re-ordering map layers in layer tree.
Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
