[GRASS-dev] Linke turbidity in r.sun.daily
Nikos Alexandris
nik at nikosalexandris.net
Fri May 15 06:34:38 PDT 2015
* Vaclav Petras <wenzeslaus at gmail.com> [2015-05-15 08:41:17 -0400]:
> On Fri, May 15, 2015 at 8:10 AM, Nikos Alexandris <nik at nikosalexandris.net>
> wrote:
> > I have another use-case, hence another update to the script. Does
> > anyone care to have a look at the proposed diff (really a quick hack, no
> > extensive testing done but it works for me).
> Looks good except for computing the slope and aspect on the fly.
> r.slope.aspect runs twice once for slope, once for aspect. With current
> code, it actually looks that there might be some override issues. Try
> harder to preserve current mechanism where one r.slope.aspect call is build
> according to missing inputs. You need to change the if conditions somehow.
> (Only reading the diff.)
Known issue, thanks for reading Vaclav. Will rework another day on it.
Nikos
