[GRASS-dev] [GRASS-SVN] r65249 - grass/trunk/raster/r.topidx
Vaclav Petras
wenzeslaus at gmail.com
Fri May 15 10:22:52 PDT 2015
Hi, I see that you are making the indent in a file consistent but I just
wanted to make sure you know that I recently updated the script
./tools/grass_indent.sh.
On Fri, May 15, 2015 at 11:42 AM, <svn_grass at osgeo.org> wrote:
> Author: hcho
> Date: 2015-05-15 08:42:52 -0700 (Fri, 15 May 2015)
> New Revision: 65249
> Modified:
> grass/trunk/raster/r.topidx/main.c
> grass/trunk/raster/r.topidx/topidx.c
> Log:
> r.topidx: indent
> Modified: grass/trunk/raster/r.topidx/main.c
> --- grass/trunk/raster/r.topidx/main.c 2015-05-15 14:45:57 UTC (rev 65248)
> +++ grass/trunk/raster/r.topidx/main.c 2015-05-15 15:42:52 UTC (rev 65249)
> @@ -51,7 +51,7 @@
> exit(EXIT_FAILURE);
> /* Make sure that the current projection is not lat/long */
> - if ((G_projection() == PROJECTION_LL))
> + if (G_projection() == PROJECTION_LL)
> G_fatal_error(_("Lat/Long location is not supported by %s. Please
> reproject map first."),
> G_program_name());
> Modified: grass/trunk/raster/r.topidx/topidx.c
> --- grass/trunk/raster/r.topidx/topidx.c 2015-05-15 14:45:57 UTC
> (rev 65248)
> +++ grass/trunk/raster/r.topidx/topidx.c 2015-05-15 15:42:52 UTC
> (rev 65249)
> @@ -125,7 +125,8 @@
> sum += route[0];
> nroute++;
> - if (!is_cv_null(i - 1, j) && cv(i, j) - cv(i - 1, j) >
> ZERO) {
> + if (!is_cv_null(i - 1, j) &&
> + cv(i, j) - cv(i - 1, j) > ZERO) {
> tanB[1] = (cv(i, j) - cv(i - 1, j)) * dx1;
> route[1] = 0.5 * dx * tanB[1];
> sum += route[1];
> @@ -148,7 +149,8 @@
> nroute++;
> if (j + 1 < window.cols) {
> - if (!is_cv_null(i, j + 1) && cv(i, j) - cv(i, j + 1) >
> ZERO) {
> + if (!is_cv_null(i, j + 1) &&
> + cv(i, j) - cv(i, j + 1) > ZERO) {
> tanB[5] = (cv(i, j) - cv(i, j + 1)) * dx1;
> route[5] = 0.5 * dx * tanB[5];
> sum += route[5];
> @@ -164,7 +166,8 @@
> sum += route[6];
> nroute++;
> - if (!is_cv_null(i + 1, j) && cv(i, j) - cv(i + 1, j) >
> ZERO) {
> + if (!is_cv_null(i + 1, j) &&
> + cv(i, j) - cv(i + 1, j) > ZERO) {
> tanB[7] = (cv(i, j) - cv(i + 1, j)) * dx1;
> route[7] = 0.5 * dx * tanB[7];
> sum += route[7];
> @@ -187,46 +190,38 @@
> nslp = 0;
> if (i > 0) {
> if (j > 0 && !is_cv_null(i - 1, j - 1)) {
> - sumtb += (cv(i - 1, j - 1)
> - - cv(i, j)) * dx2;
> + sumtb += (cv(i - 1, j - 1) - cv(i, j)) * dx2;
> nslp++;
> if (!is_cv_null(i - 1, j)) {
> - sumtb += (cv(i - 1, j)
> - - cv(i, j)) * dx1;
> + sumtb += (cv(i - 1, j) - cv(i, j)) * dx1;
> nslp++;
> if (j + 1 < window.cols && !is_cv_null(i - 1, j +
> 1)) {
> - sumtb += (cv(i - 1, j + 1)
> + sumtb += (cv(i - 1, j + 1) - cv(i, j)) * dx2;
> nslp++;
> if (j > 0 && !is_cv_null(i, j - 1)) {
> - sumtb += (cv(i, j - 1)
> + sumtb += (cv(i, j - 1) - cv(i, j)) * dx1;
> nslp++;
> if (j + 1 < window.cols && !is_cv_null(i, j + 1)) {
> - sumtb += (cv(i, j + 1)
> + sumtb += (cv(i, j + 1) - cv(i, j)) * dx1;
> nslp++;
> if (i + 1 < window.rows) {
> if (j > 0 && !is_cv_null(i + 1, j - 1)) {
> - sumtb += (cv(i + 1, j - 1)
> + sumtb += (cv(i + 1, j - 1) - cv(i, j)) * dx2;
> nslp++;
> if (!is_cv_null(i + 1, j)) {
> - sumtb += (cv(i + 1, j)
> + sumtb += (cv(i + 1, j) - cv(i, j)) * dx1;
> nslp++;
> if (j + 1 < window.cols && !is_cv_null(i + 1, j +
> 1)) {
> - sumtb += (cv(i + 1, j + 1)
> + sumtb += (cv(i + 1, j + 1) - cv(i, j)) * dx2;
> nslp++;
> grass-commit mailing list
> grass-commit at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-commit
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150515/59c6610a/attachment.html>
