[GRASS-dev] [GRASS-SVN] r65249 - grass/trunk/raster/r.topidx
Huidae Cho
grass4u at gmail.com
Fri May 15 11:04:54 PDT 2015
Hi, Thanks for pointing me to the script. I just manually adjusted several
lines to make them 80 columns. Based on the script, it looks like couple
options were dropped (-ts8, -ut) and new ones were added (-npro, --no-tabs).
On Fri, May 15, 2015 at 1:22 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> Hi, I see that you are making the indent in a file consistent but I just
> wanted to make sure you know that I recently updated the script
> ./tools/grass_indent.sh.
> On Fri, May 15, 2015 at 11:42 AM, <svn_grass at osgeo.org> wrote:
>> Author: hcho
>> Date: 2015-05-15 08:42:52 -0700 (Fri, 15 May 2015)
>> New Revision: 65249
>> Modified:
>> grass/trunk/raster/r.topidx/main.c
>> grass/trunk/raster/r.topidx/topidx.c
>> Log:
>> r.topidx: indent
>> Modified: grass/trunk/raster/r.topidx/main.c
>> --- grass/trunk/raster/r.topidx/main.c 2015-05-15 14:45:57 UTC (rev
>> 65248)
>> +++ grass/trunk/raster/r.topidx/main.c 2015-05-15 15:42:52 UTC (rev
>> 65249)
>> @@ -51,7 +51,7 @@
>> exit(EXIT_FAILURE);
>> /* Make sure that the current projection is not lat/long */
>> - if ((G_projection() == PROJECTION_LL))
>> + if (G_projection() == PROJECTION_LL)
>> G_fatal_error(_("Lat/Long location is not supported by %s. Please
>> reproject map first."),
>> G_program_name());
>> Modified: grass/trunk/raster/r.topidx/topidx.c
>> --- grass/trunk/raster/r.topidx/topidx.c 2015-05-15 14:45:57 UTC
>> (rev 65248)
>> +++ grass/trunk/raster/r.topidx/topidx.c 2015-05-15 15:42:52 UTC
>> (rev 65249)
>> @@ -125,7 +125,8 @@
>> sum += route[0];
>> nroute++;
>> - if (!is_cv_null(i - 1, j) && cv(i, j) - cv(i - 1, j)
>> > ZERO) {
>> + if (!is_cv_null(i - 1, j) &&
>> + cv(i, j) - cv(i - 1, j) > ZERO) {
>> tanB[1] = (cv(i, j) - cv(i - 1, j)) * dx1;
>> route[1] = 0.5 * dx * tanB[1];
>> sum += route[1];
>> @@ -148,7 +149,8 @@
>> nroute++;
>> if (j + 1 < window.cols) {
>> - if (!is_cv_null(i, j + 1) && cv(i, j) - cv(i, j + 1)
>> > ZERO) {
>> + if (!is_cv_null(i, j + 1) &&
>> + cv(i, j) - cv(i, j + 1) > ZERO) {
>> tanB[5] = (cv(i, j) - cv(i, j + 1)) * dx1;
>> route[5] = 0.5 * dx * tanB[5];
>> sum += route[5];
>> @@ -164,7 +166,8 @@
>> sum += route[6];
>> nroute++;
>> - if (!is_cv_null(i + 1, j) && cv(i, j) - cv(i + 1, j)
>> > ZERO) {
>> + if (!is_cv_null(i + 1, j) &&
>> + cv(i, j) - cv(i + 1, j) > ZERO) {
>> tanB[7] = (cv(i, j) - cv(i + 1, j)) * dx1;
>> route[7] = 0.5 * dx * tanB[7];
>> sum += route[7];
>> @@ -187,46 +190,38 @@
>> nslp = 0;
>> if (i > 0) {
>> if (j > 0 && !is_cv_null(i - 1, j - 1)) {
>> - sumtb += (cv(i - 1, j - 1)
>> - - cv(i, j)) * dx2;
>> + sumtb += (cv(i - 1, j - 1) - cv(i, j)) * dx2;
>> nslp++;
>> if (!is_cv_null(i - 1, j)) {
>> - sumtb += (cv(i - 1, j)
>> - - cv(i, j)) * dx1;
>> + sumtb += (cv(i - 1, j) - cv(i, j)) * dx1;
>> nslp++;
>> if (j + 1 < window.cols && !is_cv_null(i - 1, j +
>> 1)) {
>> - sumtb += (cv(i - 1, j + 1)
>> + sumtb += (cv(i - 1, j + 1) - cv(i, j)) * dx2;
>> nslp++;
>> if (j > 0 && !is_cv_null(i, j - 1)) {
>> - sumtb += (cv(i, j - 1)
>> + sumtb += (cv(i, j - 1) - cv(i, j)) * dx1;
>> nslp++;
>> if (j + 1 < window.cols && !is_cv_null(i, j + 1)) {
>> - sumtb += (cv(i, j + 1)
>> + sumtb += (cv(i, j + 1) - cv(i, j)) * dx1;
>> nslp++;
>> if (i + 1 < window.rows) {
>> if (j > 0 && !is_cv_null(i + 1, j - 1)) {
>> - sumtb += (cv(i + 1, j - 1)
>> + sumtb += (cv(i + 1, j - 1) - cv(i, j)) * dx2;
>> nslp++;
>> if (!is_cv_null(i + 1, j)) {
>> - sumtb += (cv(i + 1, j)
>> + sumtb += (cv(i + 1, j) - cv(i, j)) * dx1;
>> nslp++;
>> if (j + 1 < window.cols && !is_cv_null(i + 1, j +
>> 1)) {
>> - sumtb += (cv(i + 1, j + 1)
>> + sumtb += (cv(i + 1, j + 1) - cv(i, j)) * dx2;
>> nslp++;
>> grass-commit mailing list
>> grass-commit at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-commit
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150515/af6c7c79/attachment-0001.html>
