[GRASS-dev] [GRASS GIS] #2579: Specify command to be exectued as parameter of grass command
trac at osgeo.org
Mon May 18 11:09:09 PDT 2015
Reporter: wenzeslaus | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.1.0
Component: Startup | Version: svn-trunk
Resolution: | Keywords: batch job, GRASS_BATCH_JOB, init
CPU: Unspecified | Platform: All
Comment (by wenzeslaus):
I've updated documentation in r65269 and r65270. It is not complete (e.g.,
there are no explanations) but it should be enough to try it and use it. I
created example which uses `r.external`, `r.univar` and `g.gui.mapswipe`.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2579#comment:13>
