[GRASS-dev] [GRASS GIS] #1788: r.viewshed binary flag (-b) not working correctly
trac at osgeo.org
Mon May 18 11:47:30 PDT 2015
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: normal | Milestone: 7.0.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.viewshed
CPU: Unspecified | Platform: Unspecified
Changes (by annakrat):
* status: closed => reopened
* resolution: fixed =>
Comment:
Reopened because it works only when using internal memory. When using
external memory mode, binary output gives 1 and nulls. It doesn't seem to
be so easily fixable as the in-memory case, because I can't find an easy
way to find out which cell should be 0 and which should be null.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1788#comment:4>
