[GRASS-dev] PROJ problem compiling GRASS trunk
Anna Petrášová kratochanna at gmail.com
Mon May 18 18:40:17 PDT 2015
On Mon, May 18, 2015 at 8:49 PM, William Kyngesburye <woklist at kyngchaos.com>
wrote:
> Oops, the PROJ programs are still linked to my build.  I'll fix it soon.
I am not sure if this is related, but there is some problem with PROJ
programs not being on path. So when using m.proj which calls cs2cs, you get
an error from m.proj ("cs2cs program not found, install PROJ.4 first"). I
saw this on couple of computers which were using Michael's binaries.
Anna
> On May 18, 2015, at 2:51 PM, Michael Barton <michael.barton at asu.edu>
> wrote:
> > I just updated and tried to compile GRASS trunk. I also updated to the
> 2015-04-11 version of GDAL complete 1.11
> > When I tried compiling, I got the following error from
> /Users/cmbarton/grass_source/grass_trunk/lib/proj
> urce/grass_trunk/dist.x86_64-apple-darwin14.3.0/etc/proj/nad/src/stlrnc.lla
> /Users/cmbarton/grass_source/grass_trunk/dist.x86_64-apple-darwin14.3.0/etc/proj/nad/src/stpaul.lla
> > /Library/Frameworks/PROJ.framework/Programs/nad2bin < FL.lla
> /Users/cmbarton/grass_source/grass_trunk/dist.x86_64-apple-darwin14.3.0/etc/proj/nad/FL
> > dyld: Library not loaded:
> /Users/Shared/src/proj.4/build-4.9.1/lion/usr/lib/libproj.9.dylib
> >   Referenced from: /Library/Frameworks/PROJ.framework/Programs/nad2bin
> >   Reason: image not found
> > /bin/sh: line 1: 65178 Trace/BPT trap: 5
> < FL.lla
> > make[1]: ***
> [/Users/cmbarton/grass_source/grass_trunk/dist.x86_64-apple-darwin14.3.0/etc/proj/nad/FL]
> Error 133
> > When I rolled back to the 2014-12 version of GDAL complete 1.11, it
> compiles fine.
> > Michael
> > ____________________
> > C. Michael Barton
> > Director, Center for Social Dynamics & Complexity
> > Professor of Anthropology, School of Human Evolution & Social Change
> > Head, Graduate Faculty in Complex Adaptive Systems Science
> > Arizona State University
> > voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> > fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
> > www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> > grass-dev mailing list
> > grass-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-dev
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "We are at war with them. Neither in hatred nor revenge and with no
> particular pleasure I shall kill every ___ I can until the war is over.
> That is my duty."
> "Don't you even hate 'em?"
> "What good would it do if I did? If all the many millions of people of the
> allied nations devoted an entire year exclusively to hating the ____ it
> wouldn't kill one ___ nor shorten the war one day."
> <Ha, ha> "And it might give 'em all stomach ulcers."
> - Tarzan, on war
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150518/d6ea48cf/attachment-0001.html>
