[GRASS-dev] PROJ problem compiling GRASS trunk
Michael Barton Michael.Barton at asu.edu
Mon May 18 22:37:28 PDT 2015
I might have a hack to fix this. I add one of the programs to the path at compile time and could add the others too.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On May 18, 2015, at 6:40 PM, Anna Petrášová <kratochanna at gmail.com<mailto:kratochanna at gmail.com>> wrote:
On Mon, May 18, 2015 at 8:49 PM, William Kyngesburye <woklist at kyngchaos.com<mailto:woklist at kyngchaos.com>> wrote:
Oops, the PROJ programs are still linked to my build.  I'll fix it soon.
I am not sure if this is related, but there is some problem with PROJ programs not being on path. So when using m.proj which calls cs2cs, you get an error from m.proj ("cs2cs program not found, install PROJ.4 first"). I saw this on couple of computers which were using Michael's binaries.
Anna
On May 18, 2015, at 2:51 PM, Michael Barton <michael.barton at asu.edu<mailto:michael.barton at asu.edu>> wrote:
> I just updated and tried to compile GRASS trunk. I also updated to the 2015-04-11 version of GDAL complete 1.11
> When I tried compiling, I got the following error from /Users/cmbarton/grass_source/grass_trunk/lib/proj
> urce/grass_trunk/dist.x86_64-apple-darwin14.3.0/etc/proj/nad/src/stlrnc.lla /Users/cmbarton/grass_source/grass_trunk/dist.x86_64-apple-darwin14.3.0/etc/proj/nad/src/stpaul.lla
> /Library/Frameworks/PROJ.framework/Programs/nad2bin < FL.lla /Users/cmbarton/grass_source/grass_trunk/dist.x86_64-apple-darwin14.3.0/etc/proj/nad/FL
> dyld: Library not loaded: /Users/Shared/src/proj.4/build-4.9.1/lion/usr/lib/libproj.9.dylib
>   Referenced from: /Library/Frameworks/PROJ.framework/Programs/nad2bin
>   Reason: image not found
> /bin/sh: line 1: 65178 Trace/BPT trap: 5       /Library/Frameworks/PROJ.framework/Programs/nad2bin /Users/cmbarton/grass_source/grass_trunk/dist.x86_64-apple-darwin14.3.0/etc/proj/nad/FL < FL.lla
> make[1]: *** [/Users/cmbarton/grass_source/grass_trunk/dist.x86_64-apple-darwin14.3.0/etc/proj/nad/FL] Error 133
> When I rolled back to the 2014-12 version of GDAL complete 1.11, it compiles fine.
> Michael
> C. Michael Barton
> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu<http://csdc.asu.edu/>
> grass-dev mailing list
> grass-dev at lists.osgeo.org<mailto:grass-dev at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/grass-dev
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"We are at war with them. Neither in hatred nor revenge and with no particular pleasure I shall kill every ___ I can until the war is over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people of the allied nations devoted an entire year exclusively to hating the ____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
- Tarzan, on war
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150519/dd4f63b8/attachment-0001.html>
