[GRASS-dev] GRASS trunk will no longer compile for Mac
Anna Petrášová
kratochanna at gmail.com
Tue May 19 10:11:47 PDT 2015
On Tue, May 19, 2015 at 1:05 PM, Michael Barton <Michael.Barton at asu.edu>
wrote:
> I built GRASS 7.1 with no problems
> I launched it with no problems.
> BUT, ran into a weird problem rendering maps
> If I open a raster and a vector (elevations and streams from the
> nc_spm_08 demo set) they render fine
> If I switch to 3D, it renders fine
> If I switch back to 2D, rendering hangs with no error messages
I assume you are using wxpython 2.8, right? There have been big changes
recently in rendering, that might be one possible source of problems. I
will try to compile it as well and see if I have the same problem.
Anna
> The only thing I’ve done differently is to add the following to my shell
> setup prior to compiling
> export CS2CS=/Library/Frameworks/PROJ.framework/Programs/cs2cs
> export GEOD=/Library/Frameworks/PROJ.framework/Programs/geod
> I already use with no problem the following
> export NAD2BIN=/Library/Frameworks/PROJ.framework/Programs/nad2bin
> Michael
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Head, Graduate Faculty in Complex Adaptive Systems Science
> Arizona State University
> voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> On May 18, 2015, at 7:40 PM, Michael Barton <Michael.Barton at asu.edu>
> wrote:
> Argh. Will try again tomorrow. Thanks for letting me know.
> Cheers
> Michael
> Michael Barton
> School of Human Evolution &Social Change
> ...Sent from my iPad
> On May 18, 2015, at 6:35 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Mon, May 18, 2015 at 6:31 PM, Michael Barton <Michael.Barton at asu.edu>
> wrote:
>> A completely new installation compiled without error but will not launch
>> with yet new errors.
>> Michael
>> Last login: Mon May 18 15:28:40 on ttys001
>> cmb-imaccsdc-2:~ cmbarton$
>> '/Applications/GRASS-7.1.app/Contents/MacOS/grass.sh'; exit
>> Rebuilding Addon HTML manual pages index...
>> Rebuilding Addon menu...
>> Python 2.7.6 found.
>> Traceback (most recent call last):
>> File "/Applications/GRASS-7.1.app/Contents/MacOS/grass71", line 1507,
>> in <module>
>> params = parse_cmdline(sys.argv[1:])
>> File "/Applications/GRASS-7.1.app/Contents/MacOS/grass71", line 1424,
>> in parse_cmdline
>> params.mapset = args[0]
>> IndexError: list index out of range
>> logout
> Please do svn up again. The error was there between 12:36:53 PM (6 hours
> ago) and 2:57:19 PM (4 hours ago). Sorry for the inconvenience.
> https://trac.osgeo.org/grass/changeset/65275
> https://trac.osgeo.org/grass/changeset/65274
>> [Process completed]
>> C. Michael Barton
>> On May 18, 2015, at 1:50 PM, Anna Petrášová <kratochanna at gmail.com>
>> wrote:
>> On Mon, May 18, 2015 at 4:22 PM, Michael Barton <Michael.Barton at asu.edu>
>> wrote:
>>> Although GRASS compiles without error, it fails on launch with the
>>> errors listed below. This was all working a few months back. So some new
>>> change has broken it again. Same wxgui stuff as before.
>>> Michael
>>> File
>>> "/Users/cmbarton/grass_source/grass_trunk/macosx/dist/GRASS-7.1.app/Contents/MacOS/gui/wxpython/wxgui.py",
>>> line 140, in <module>
>>> sys.exit(main())
>>> File
>>> line 132, in main
>>> app = GMApp(workspaceFile)
>>> File
>>> line 46, in __init__
>>> wx.App.__init__(self, False)
>>> File
>>> "/Users/cmbarton/grass_source/grass_trunk/macosx/dist/GRASS-7.1.app/Contents/MacOS/etc/python/wx/_core.py",
>>> line 7981, in __init__
>>> self._BootstrapApp()
>>> File
>>> line 7555, in _BootstrapApp
>>> return _core_.PyApp__BootstrapApp(*args, **kwargs)
>>> File
>>> line 79, in OnInit
>>> from lmgr.frame import GMFrame
>>> File
>>> "/Users/cmbarton/grass_source/grass_trunk/macosx/dist/GRASS-7.1.app/Contents/MacOS/gui/wxpython/lmgr/frame.py",
>>> line 50, in <module>
>>> from lmgr.layertree import LayerTree, LMIcons
>>> File
>>> "/Users/cmbarton/grass_source/grass_trunk/macosx/dist/GRASS-7.1.app/Contents/MacOS/gui/wxpython/lmgr/layertree.py",
>>> line 37, in <module>
>>> from mapdisp.frame import MapFrame
>>> File
>>> "/Users/cmbarton/grass_source/grass_trunk/macosx/dist/GRASS-7.1.app/Contents/MacOS/gui/wxpython/mapdisp/frame.py",
>>> line 34, in <module>
>>> from vdigit.toolbars import VDigitToolbar
>>> File
>>> "/Users/cmbarton/grass_source/grass_trunk/macosx/dist/GRASS-7.1.app/Contents/MacOS/gui/wxpython/vdigit/toolbars.py",
>>> line 30, in <module>
>>> from iclass.digit import IClassVDigit
>>> File
>>> "/Users/cmbarton/grass_source/grass_trunk/macosx/dist/GRASS-7.1.app/Contents/MacOS/gui/wxpython/iclass/digit.py",
>>> line 23, in <module>
>>> from vdigit.wxdisplay import DisplayDriver, TYPE_AREA
>>> ImportError: cannot import name TYPE_AREA
>> Please try again, we had this before and it was just a mistake, so
>> hopefully nothing is broken
>> http://trac.osgeo.org/grass/ticket/2538
>> Anna
>>> C. Michael Barton
>>> grass-dev mailing list
>>> grass-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150519/b05bf5f8/attachment-0001.html>
