[GRASS-dev] GRASS trunk will no longer compile for Mac
Michael Barton
Michael.Barton at asu.edu
Tue May 19 10:23:40 PDT 2015
I’ve been sticking with wxPython 2.8.12 until we work out v. 3.
I’d hoped to get out a new version before I leave for Europe on Friday. But I might have to wait until I get back at the end of June if this is getting complicated.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On May 19, 2015, at 10:11 AM, Anna Petrášová <kratochanna at gmail.com<mailto:kratochanna at gmail.com>> wrote:
On Tue, May 19, 2015 at 1:05 PM, Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>> wrote:
I built GRASS 7.1 with no problems
I launched it with no problems.
BUT, ran into a weird problem rendering maps
If I open a raster and a vector (elevations and streams from the nc_spm_08 demo set) they render fine
If I switch to 3D, it renders fine
If I switch back to 2D, rendering hangs with no error messages
I assume you are using wxpython 2.8, right? There have been big changes recently in rendering, that might be one possible source of problems. I will try to compile it as well and see if I have the same problem.
Anna
The only thing I’ve done differently is to add the following to my shell setup prior to compiling
export CS2CS=/Library/Frameworks/PROJ.framework/Programs/cs2cs
export GEOD=/Library/Frameworks/PROJ.framework/Programs/geod
I already use with no problem the following
export NAD2BIN=/Library/Frameworks/PROJ.framework/Programs/nad2bin
Michael
C. Michael Barton
voice: 480-965-6262<tel:480-965-6262> (SHESC), 480-965-8130<tel:480-965-8130>/727-9746 (CSDC)
fax: 480-965-7671<tel:480-965-7671> (SHESC), 480-727-0709<tel:480-727-0709> (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu<http://csdc.asu.edu/>
On May 18, 2015, at 7:40 PM, Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>> wrote:
Argh. Will try again tomorrow. Thanks for letting me know.
Cheers
Michael
Michael Barton
School of Human Evolution &Social Change
...Sent from my iPad
On May 18, 2015, at 6:35 PM, Vaclav Petras <wenzeslaus at gmail.com<mailto:wenzeslaus at gmail.com>> wrote:
On Mon, May 18, 2015 at 6:31 PM, Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>> wrote:
A completely new installation compiled without error but will not launch with yet new errors.
Michael
Last login: Mon May 18 15:28:40 on ttys001
cmb-imaccsdc-2:~ cmbarton$ '/Applications/GRASS-7.1.app/Contents/MacOS/grass.sh'; exit
Rebuilding Addon HTML manual pages index...
Rebuilding Addon menu...
Python 2.7.6 found.
File "/Applications/GRASS-7.1.app/Contents/MacOS/grass71", line 1507, in <module>
params = parse_cmdline(sys.argv[1:])
File "/Applications/GRASS-7.1.app/Contents/MacOS/grass71", line 1424, in parse_cmdline
params.mapset = args[0]
IndexError: list index out of range
logout
Please do svn up again. The error was there between 12:36:53 PM (6 hours ago) and 2:57:19 PM (4 hours ago). Sorry for the inconvenience.
https://trac.osgeo.org/grass/changeset/65275
https://trac.osgeo.org/grass/changeset/65274
[Process completed]
C. Michael Barton
On May 18, 2015, at 1:50 PM, Anna Petrášová <kratochanna at gmail.com<mailto:kratochanna at gmail.com>> wrote:
On Mon, May 18, 2015 at 4:22 PM, Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>> wrote:
Although GRASS compiles without error, it fails on launch with the errors listed below. This was all working a few months back. So some new change has broken it again. Same wxgui stuff as before.
Michael
File "/Users/cmbarton/grass_source/grass_trunk/macosx/dist/GRASS-7.1.app/Contents/MacOS/gui/wxpython/wxgui.py", line 140, in <module>
sys.exit(main())
File "/Users/cmbarton/grass_source/grass_trunk/macosx/dist/GRASS-7.1.app/Contents/MacOS/gui/wxpython/wxgui.py", line 132, in main
app = GMApp(workspaceFile)
File "/Users/cmbarton/grass_source/grass_trunk/macosx/dist/GRASS-7.1.app/Contents/MacOS/gui/wxpython/wxgui.py", line 46, in __init__
wx.App.__init__(self, False)
File "/Users/cmbarton/grass_source/grass_trunk/macosx/dist/GRASS-7.1.app/Contents/MacOS/etc/python/wx/_core.py", line 7981, in __init__
self._BootstrapApp()
File "/Users/cmbarton/grass_source/grass_trunk/macosx/dist/GRASS-7.1.app/Contents/MacOS/etc/python/wx/_core.py", line 7555, in _BootstrapApp
return _core_.PyApp__BootstrapApp(*args, **kwargs)
File "/Users/cmbarton/grass_source/grass_trunk/macosx/dist/GRASS-7.1.app/Contents/MacOS/gui/wxpython/wxgui.py", line 79, in OnInit
from lmgr.frame import GMFrame
File "/Users/cmbarton/grass_source/grass_trunk/macosx/dist/GRASS-7.1.app/Contents/MacOS/gui/wxpython/lmgr/frame.py", line 50, in <module>
from lmgr.layertree import LayerTree, LMIcons
File "/Users/cmbarton/grass_source/grass_trunk/macosx/dist/GRASS-7.1.app/Contents/MacOS/gui/wxpython/lmgr/layertree.py", line 37, in <module>
from mapdisp.frame import MapFrame
File "/Users/cmbarton/grass_source/grass_trunk/macosx/dist/GRASS-7.1.app/Contents/MacOS/gui/wxpython/mapdisp/frame.py", line 34, in <module>
from vdigit.toolbars import VDigitToolbar
File "/Users/cmbarton/grass_source/grass_trunk/macosx/dist/GRASS-7.1.app/Contents/MacOS/gui/wxpython/vdigit/toolbars.py", line 30, in <module>
from iclass.digit import IClassVDigit
File "/Users/cmbarton/grass_source/grass_trunk/macosx/dist/GRASS-7.1.app/Contents/MacOS/gui/wxpython/iclass/digit.py", line 23, in <module>
from vdigit.wxdisplay import DisplayDriver, TYPE_AREA
ImportError: cannot import name TYPE_AREA
Please try again, we had this before and it was just a mistake, so hopefully nothing is broken
http://trac.osgeo.org/grass/ticket/2538
Anna
C. Michael Barton
grass-dev mailing list
grass-dev at lists.osgeo.org<mailto:grass-dev at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150519/65d33b0e/attachment-0001.html>
