[GRASS-dev] Failing tests overview for September 2015
Vaclav Petras
wenzeslaus at gmail.com
Tue Nov 3 09:52:07 PST 2015
On Tue, Nov 3, 2015 at 6:50 AM, Markus Neteler <neteler at osgeo.org> wrote:
> Hi again,
> in addition, I feel that the Piemonte dataset on the server needs to be
> updated.
> e.g.
> http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-11-02-08-00/report_for_piemonte_utm32_wgs84_grass7_stdmaps/vector/v.net/test_v_net/index.html
> --> ERROR: Vector map <streets> not found
> http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-11-02-08-00/report_for_piemonte_utm32_wgs84_grass7_stdmaps/raster/r.viewshed/test_r_viewshed/index.html
> --> ERROR: Raster map <elevation> not found
> (many more like that)
> For our recent IRSAE course, we have prepared an updated version which
> complies to the agreed upon map names:
> https://trac.osgeo.org/grass/wiki/SampleDataset/Italy/Piemont
> --> Download of draft location package
> --> 7z compressed file
> This dataset is to be further updated but already way closer to the
> final version and it used the standard names.
> Vaclav, could you please replace the Piemonte dataset on your test server?
Where to get the updated version? I already downloaded the one linked from
the page linked from Trac but now I'm looking at it and it is still the one
with old names.
> thanks,
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151103/5507f301/attachment.html>
