[GRASS-dev] [GRASS GIS] #2670: v.voronoi skeleton: nonsense result with many adjacent polygons
GRASS GIS trac at osgeo.org
Wed Nov 4 01:54:53 PST 2015
  Reporter:  mlennert     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.0.2
 Component:  Default      |    Version:  svn-trunk
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by sbl):
 I can second that.
 I tried v.voronoi -s on both a set of isolated lake and valley polygons.
 There using a loop helped, but results were not very promising never the
 less, esp. for relatively complex polygons with many vertices. See e.g.
 how the centerline is routed around islands...
 So I tried to generalize the polygons in advance. That improved the
 results in areas where vertex density was high but led to unuseful results
 where vertex density was low (within one polygon)...
Ticket URL: <https://trac.osgeo.org/grass/ticket/2670#comment:2>
