[GRASS-dev] Return value from g.copy is one when --overwrite - bug or feature?
Rainer M Krug
Rainer at krugs.de
Fri Nov 6 05:21:24 PST 2015
When copying via g.copy and specifying --overwrite and the target object
already exists, the return value is 1 but no error message is returned:
| simASM:grassAnalysis> g.copy --overwrite region=region1,region2
| simASM:grassAnalysis> echo $?
| 1
| simASM:grassAnalysis> g.version
| GRASS 7.0.1 (2015)
From http://tldp.org/LDP/abs/html/exit-status.html:
| A successful command returns a 0, while an unsuccessful one returns a
| non-zero value that usually can be interpreted as an error code.
So shouldn't the return value be 0 in this case, as the command did what
it was told?
Cheers,
Rainer
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer at krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151106/7ecc5ea4/attachment.sig>
