[GRASS-dev] Return value from g.copy is one when --overwrite - bug or feature?
Huidae Cho
grass4u at gmail.com
Fri Nov 6 13:55:05 PST 2015
Rainer,
I cannot seem to replicate your issue:
G srorg6630/tmp ~> g.version
GRASS 7.1.svn (2015)
G srorg6630/tmp ~> g.list region
tmp
tmp.d.rast.edit.6753
tmp1
G srorg6630/tmp ~> g.copy region=tmp,tmp1 --overwrite
Copy region definition <tmp at tmp> to current mapset as <tmp1>
G srorg6630/tmp ~> echo $?
0
g.copy returns 1 when it cannot either read the source or write to the
target. Please check your permissions on your region files in
LOCATION/MAPSET/windows/.
Regards,
Huidae
On Fri, Nov 6, 2015 at 8:21 AM, Rainer M Krug <Rainer at krugs.de> wrote:
> When copying via g.copy and specifying --overwrite and the target object
> already exists, the return value is 1 but no error message is returned:
> | simASM:grassAnalysis> g.copy --overwrite region=region1,region2
> | simASM:grassAnalysis> echo $?
> | 1
> | simASM:grassAnalysis> g.version
> | GRASS 7.0.1 (2015)
> From http://tldp.org/LDP/abs/html/exit-status.html:
> | A successful command returns a 0, while an unsuccessful one returns a
> | non-zero value that usually can be interpreted as an error code.
> So shouldn't the return value be 0 in this case, as the command did what
> it was told?
> Cheers,
> Rainer
> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
> Biology, UCT), Dipl. Phys. (Germany)
> Centre of Excellence for Invasion Biology
> Stellenbosch University
> South Africa
> Tel : +33 - (0)9 53 10 27 44
> Cell: +33 - (0)6 85 62 59 98
> Fax : +33 - (0)9 58 10 27 44
> Fax (D): +49 - (0)3 21 21 25 22 44
> email: Rainer at krugs.de
> Skype: RMkrug
> PGP: 0x0F52F982
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151106/a0401d64/attachment.html>
