[GRASS-dev] Return value from g.copy is one when --overwrite - bug or feature?
Rainer M Krug Rainer at krugs.de
Mon Nov 9 00:50:15 PST 2015
Markus Neteler <neteler at osgeo.org> writes:
> On Sun, Nov 8, 2015 at 11:22 AM, Rainer M Krug <Rainer at krugs.de> wrote:
>> Huidae Cho <grass4u at gmail.com> writes:
>>> Rainer,
>>> I cannot seem to replicate your issue:
>>> G srorg6630/tmp ~> g.version
>>> GRASS 7.1.svn (2015)
>>> G srorg6630/tmp ~> g.list region
>>> tmp
>>> tmp.d.rast.edit.6753
>>> tmp1
>>> G srorg6630/tmp ~> g.copy region=tmp,tmp1 --overwrite
>>> Copy region definition <tmp at tmp> to current mapset as <tmp1>
>>> G srorg6630/tmp ~> echo $?
>>> 0
>>> g.copy returns 1 when it cannot either read the source or write to the
>>> target. Please check your permissions on your region files in
>>> LOCATION/MAPSET/windows/.
>> You are correct - they are read only.
>> So the return value is correct - but an error should be raised - or is
>> there a reason why this should silently fail?
> It should probably not silently fail.
Absolutely not - this can lead to errors as one assumes that no error
message means that the command was successful - I usually don't check
the return codes when I am working in a terminal.
> The code in question is in
> lib/manage/do_copy.c
> and potentially there to be added strerror(errno) as for example in
> lib/gis/mapset_msc.c
I don't know the inner workings of GRASS - but it looks like a good place?
On a related note - are the return codes documented somewhere (apart
From the source code)? OK - 0 is evident, but the others? They seem to
have specific meanings in GRASS?
Thanks,
Rainer
> Markus
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel :       +33 - (0)9 53 10 27 44
Cell:       +33 - (0)6 85 62 59 98
Fax :       +33 - (0)9 58 10 27 44
Fax (D):    +49 - (0)3 21 21 25 22 44
email:      Rainer at krugs.de
Skype:      RMkrug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151109/07123bd8/attachment.sig>
