[GRASS-dev] Broken: GRASS-GIS/grass-ci#478 (master - e2f3140)
Maris Nartiss
maris.gis at gmail.com
Tue Nov 10 14:12:48 PST 2015
There is a mistake in Make files. I observed such failure with
parallel make, but everything seems to be OK when not building in
parallel. (run make distclean followed by make -j 4 and most likely
you will trigger the issue)
Māris.
2015-11-10 16:39 GMT+02:00 Vaclav Petras <wenzeslaus at gmail.com>:
> On Mon, Nov 9, 2015 at 7:14 AM, Travis CI <builds at travis-ci.org> wrote:
>> GRASS-GIS / grass-ci (master)
>> Build #478 was broken.
>> 6 minutes and 10 seconds
>> Glynn Clements e2f3140 Changeset →
>> Include dbstubs.h, fix prototypes for open_select_cursor and
>> describe_table
>> git-svn-id: https://svn.osgeo.org/grass/grass/trunk@66773
>> 15284696-431f-4ddb-bdfa-cd5b030d7da7
> From the raw log [2] it seems that this is the error:
> add_col.c:2:27: fatal error: grass/dbstubs.h: No such file or directory
> However, in my local copy I don't get this error and the file is in the
> distribution at the right place:
> $ find . -name "*dbstubs.h"
> ./lib/db/dbmi_driver/dbstubs.h
> ./dist.x86_64-unknown-linux-gnu/include/grass/dbstubs.h
> I'm not getting any errors after cd into the directories reported by make. I
> don't know how to fix this.
> Vaclav
> [1] https://travis-ci.org/GRASS-GIS/grass-ci/jobs/90080323
> [2] https://s3.amazonaws.com/archive.travis-ci.org/jobs/90080323/log.txt
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
