[GRASS-dev] Broken: GRASS-GIS/grass-ci#478 (master - e2f3140)
Martin Landa
landa.martin at gmail.com
Wed Nov 11 10:50:29 PST 2015
2015-11-10 23:12 GMT+01:00 Maris Nartiss <maris.gis at gmail.com>:
> There is a mistake in Make files. I observed such failure with
> parallel make, but everything seems to be OK when not building in
> parallel. (run make distclean followed by make -j 4 and most likely
> you will trigger the issue)
this is not this case I am getting the same error also when building
with `make -j1`. Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
