[GRASS-dev] Broken: GRASS-GIS/grass-ci#478 (master - e2f3140)
Thu Nov 12 01:28:25 PST 2015
Vaclav Petras wrote:
> I'm not getting any errors after cd into the directories reported by make.
> I don't know how to fix this.
The header is installed when making lib/db/dbmi_driver, but
lib/db/dbstubs is typically made first.
It will probably work for incremental builds (which is probably why I
failed to notice this before committing) and may work for parallel
builds.
r66817 moves dbstubs.h to lib/db/dbmi_base, which is an explicit
pre-requisite of both dbmi_driver and stubs.
