[GRASS-dev] [GRASS-SVN] r66823 - grass/trunk/vector/v.in.lidar
Martin Landa
landa.martin at gmail.com
Thu Nov 12 15:07:34 PST 2015
2015-11-12 23:51 GMT+01:00 <svn_grass at osgeo.org>:
> Author: wenzeslaus
> Date: 2015-11-12 14:51:02 -0800 (Thu, 12 Nov 2015)
> New Revision: 66823
> Modified:
> grass/trunk/vector/v.in.lidar/main.c
> Log:
> v.in.lidar: import points only in selected areas [news]
I like your idea (if I understand well, it's a tag which should help
us to collect release news). I would suggest also to other devs to use
it. Martin
> --- grass/trunk/vector/v.in.lidar/main.c 2015-11-12 22:28:39 UTC (rev 66822)
> +++ grass/trunk/vector/v.in.lidar/main.c 2015-11-12 22:51:02 UTC (rev 66823)
> @@ -113,11 +113,13 @@
> struct GModule *module;
> struct Option *in_opt, *out_opt, *spat_opt, *filter_opt, *class_opt;
> struct Option *id_layer_opt, *return_layer_opt, *class_layer_opt;
> + struct Option *vector_mask_opt, *vector_mask_field_opt;
> struct Option *skip_opt, *preserve_opt, *offset_opt, *limit_opt;
> struct Option *outloc_opt;
> struct Flag *print_flag, *notab_flag, *region_flag, *notopo_flag;
> struct Flag *nocats_flag;
> struct Flag *over_flag, *extend_flag, *no_import_flag;
> + struct Flag *invert_mask_flag;
> char buf[2000];
> struct Key_Value *loc_proj_info = NULL, *loc_proj_units = NULL;
> struct Key_Value *proj_info, *proj_units;
> @@ -155,12 +157,12 @@
> unsigned long long n_features; /* what libLAS reports as point count */
> unsigned long long points_imported; /* counter how much we have imported */
> unsigned long long feature_count, n_outside,
> - n_filtered, n_class_filtered, not_valid;
> + n_outside_mask, n_filtered, n_class_filtered, not_valid;
> #else
> unsigned long n_features;
> unsigned long points_imported;
> unsigned long feature_count, n_outside,
> #endif
> int overwrite;
> @@ -227,6 +229,18 @@
> "If not specified, all points are imported.");
> class_opt->guisection = _("Selection");
> + vector_mask_opt = G_define_standard_option(G_OPT_V_INPUT);
> + vector_mask_opt->key = "mask";
> + vector_mask_opt->required = NO;
> + vector_mask_opt->label = _("Areas where to import points");
> + vector_mask_opt->description = _("Name of vector map with areas where the points should be imported");
> + vector_mask_opt->guisection = _("Selection");
> + vector_mask_field_opt = G_define_standard_option(G_OPT_V_FIELD);
> + vector_mask_field_opt->key = "mask_layer";
> + vector_mask_field_opt->label = _("Layer number or name for mask option");
> + vector_mask_field_opt->guisection = _("Selection");
> skip_opt = G_define_option();
> skip_opt->key = "skip";
> skip_opt->type = TYPE_INTEGER;
> @@ -283,6 +297,11 @@
> region_flag->guisection = _("Selection");
> region_flag->description = _("Limit import to the current region");
> + invert_mask_flag = G_define_flag();
> + invert_mask_flag->key = 'i';
> + invert_mask_flag->description = _("Invert mask when selecting points");
> + invert_mask_flag->guisection = _("Selection");
> extend_flag = G_define_flag();
> extend_flag->key = 'e';
> extend_flag->description =
> @@ -752,6 +771,23 @@
> db_begin_transaction(driver);
> + struct Map_info vector_mask;
> + int naareas;
> + int aarea;
> + struct bound_box *mask_area_boxes;
> + int invert_mask = 0;
> + if (vector_mask_opt->answer) {
> + if (Vect_open_old2(&vector_mask, vector_mask_opt->answer, "", vector_mask_field_opt->answer) < 2)
> + G_fatal_error(_("Failed to open vector <%s>"), vector_mask_opt->answer);
> + naareas = Vect_get_num_areas(&vector_mask);
> + mask_area_boxes = G_malloc(naareas * sizeof(struct bound_box));
> + for (aarea = 1; aarea <= naareas; aarea++) {
> + Vect_get_area_box(&vector_mask, aarea, &mask_area_boxes[aarea - 1]);
> + if (invert_mask_flag->answer)
> + invert_mask = 1;
> /* Import feature */
> points_imported = 0;
> cat = 1;
> @@ -760,6 +796,7 @@
> n_outside = 0;
> n_filtered = 0;
> n_class_filtered = 0;
> + n_outside_mask = 0;
> Points = Vect_new_line_struct();
> Cats = Vect_new_cats_struct();
> @@ -817,6 +854,19 @@
> continue;
> + skipme = TRUE;
> + if (Vect_point_in_area(x, y, &vector_mask, aarea, &mask_area_boxes[aarea - 1])) {
> + skipme = FALSE;
> + break;
> + if (invert_mask ^ skipme) {
> + n_outside_mask++;
> + continue;
> if (return_filter != LAS_ALL) {
> int return_no = LASPoint_GetReturnNumber(LAS_point);
> int n_returns = LASPoint_GetNumberOfReturns(LAS_point);
> @@ -992,6 +1042,11 @@
> db_close_database_shutdown_driver(driver);
> + Vect_close(&vector_mask);
> + G_free(mask_area_boxes);
> LASSRS_Destroy(LAS_srs);
> LASHeader_Destroy(LAS_header);
> LASReader_Destroy(LAS_reader);
> @@ -1004,7 +1059,7 @@
> /* can be easily determined only when iterated over all points */
> if (!limit_n && !cat_max_reached && points_imported != n_features
> - not_valid - n_outside - n_filtered - n_class_filtered
> - - offset_n_counter - n_count_filtered)
> + - n_outside_mask - offset_n_counter - n_count_filtered)
> G_warning(_("The underlying libLAS library is at its limits."
> " Previously reported counts might have been distorted."
> " However, the import itself should be unaffected."));
> @@ -1018,6 +1073,8 @@
> G_message(_("%llu input points were not valid"), not_valid);
> if (n_outside)
> G_message(_("%llu input points were outside of the selected area"), n_outside);
> + if (n_outside_mask)
> + G_message(_("%llu input points were outside of the area specified by mask"), n_outside_mask);
> if (n_filtered)
> G_message(_("%llu input points were filtered out by return number"), n_filtered);
> if (n_class_filtered)
> @@ -1035,6 +1092,8 @@
> G_message(_("%lu input points were not valid"), not_valid);
> if (n_outside)
> G_message(_("%lu input points were outside of the selected area"), n_outside);
> + G_message(_("%lu input points were outside of the area specified by mask"), n_outside_mask);
> if (n_filtered)
> G_message(_("%lu input points were filtered out by return number"), n_filtered);
> grass-commit mailing list
> grass-commit at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-commit
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
